Ali Posted June 14, 2007 Share Posted June 14, 2007 Hi I have a 1999 GS400 with about 88000 miles on it and I am getting a noise coming from the back when I switch gears and let go of the brake. I also get the noise when I slam on the brakes. The noise sounds like something is jamming up could you guys help what the problem might be? And the noise from the front of the car is a popping noise when I switch gears or if I go over a bump or when I turn. It’s not the wheel or hub bearings it’s not either a control arm or tie end rod cause I got it checked out from Honda because I bought the car and they cant seem to find the problem so could you guys help me what problem might be? Also is it necessary to change the water pump when you change the timing belt? Quote Link to comment Share on other sites More sharing options...
