hey guys i found a cheap compressor and this is what it says:
will it work on my 92 es300?
thanks in advance.
1994-1998
Lexus
ES300
All
Remanufactured Compressor & Clutch
COMPR TYPE: 10PA17C - w/BELLY SWITCH PORT
1999
Lexus
RX300
All
COMPR TYPE: 10PA17C - w/BELLY SWITCH PORT - TO 03/99
1995-1998
Toyota
Avalon
All
NO! All those compressors you listed are designed to use R-134a coolant. Your car was designed to use R12 Freon. Lexus switched to R-134a starting with their 1994 ES because of a mandate outlawing R12 Freon for use in automobile air conditioners. The R12 Freon depletes the ozone layer.
You can upgrade your air conditioner system to use this R-134a, but it requires that you buy a new/rebuilt compressor plus other parts to make it work properly.
they dont make r 12 freon anymore do they?
and the used compressor i bought that only worked for one week, the idiot mechanic put 134 a in it and said it will be just fine.
Private individuals cannot purchase R-12 and professionals can with IMACA or ASE permits. Even then it has to be 30# service tanks. R-12 (Freon) has not been manufactured since 1995.
just a quick question here. Does my 1994 ES300 absolutly have r134a?
[/quote
Can't tell you for sure since that was the change over year......From my understanding some of the early models of 1994 Lexus' still used R12.
IDK about the ES/Windom's, but the Camry's didn't change until 95/96. (half generation update)
I would think R12 in the '94. You can buy a product called Freeze 12 that will fill & lubricate it R12 systems. That's good to know. ;)
To answer the qestion specifically I would *think* the compressor will physically align, bolt in, and connect. But you must fill the compressor with the correct gas (because they use different lubricating oils) otherwise you'll just blow the seals in the compressor as it burns up from a lack of lubrication.
There should be a sticker under the hood I think.
I bought a new 1994 ES300 with a build date of April, 1994 and this cars air conditioning system HAD R-134a as the refrigerant, NOT R12! Like I said in my previous post, this changeover was done sometime in 1994. This was told to me by the Lexus service department that I deal with.
That's cool, but I've servied 94 & 95 vehicles with R12 myself :\ so they apparantly didn't get them all done in time?
I had my '93 ES300 converted to R-134 a while ago (2 years??). Easy for an A/C shop to do. They just pumped out all the old R-12 and oil, changed the receiver/drier and some o-rings and refilled with R-134 and new oil. Original compressor, condenser, etc. left in place and untouched. A/C has worked perfectly ever since, no issues at all.
tck...
hey,
i called a local shop and they said it would work.
It wouldent hurt to put a 134a compressor on my 92
and the change kit from r12 and 134a or w.e u call it is not necesary.
im lost!!!
so lets say i put a 92 on mine and it fits and everything and i out the 134a in it the compresor uses, why wouldent it work?
