mb770 Posted June 7, 2007 Share Posted June 7, 2007 when i turn on A/C a squeaking begins and continues until u turn it off 1999 rx 300 with 108K miles looks like one belt on entire engine ? and its tight as a guitar string any help out there? Quote Link to comment Share on other sites More sharing options...
gidoks Posted June 19, 2007 Share Posted June 19, 2007 when i turn on A/C a squeaking begins and continues until u turn it off1999 rx 300 with 108K miles looks like one belt on entire engine ? and its tight as a guitar string any help out there? What I did to solve that problem after searching in this forum was to raise the A/C setting. I raised mine to 75 degrees F and it stopped the noise. In other words, you reduce the load on the A/C preventing it from blasting at full fan speed. Quote Link to comment Share on other sites More sharing options...
retired00 Posted June 19, 2007 Share Posted June 19, 2007 when i turn on A/C a squeaking begins and continues until u turn it off1999 rx 300 with 108K miles looks like one belt on entire engine ? and its tight as a guitar string any help out there? If it's still the original, time for a new belt. Even if it is newer, it could be glazed and no longer pliable, causing the squeal. Quote Link to comment Share on other sites More sharing options...
