mb770 Posted June 7, 2007 Report Share Posted June 7, 2007 when i turn on A/C a squeaking begins and continues until u turn it off 1999 rx 300 with 108K miles looks like one belt on entire engine ? and its tight as a guitar string any help out there? Quote Link to comment Share on other sites More sharing options...
gidoks Posted June 19, 2007 Report Share Posted June 19, 2007 when i turn on A/C a squeaking begins and continues until u turn it off1999 rx 300 with 108K miles looks like one belt on entire engine ? and its tight as a guitar string any help out there? What I did to solve that problem after searching in this forum was to raise the A/C setting. I raised mine to 75 degrees F and it stopped the noise. In other words, you reduce the load on the A/C preventing it from blasting at full fan speed. Quote Link to comment Share on other sites More sharing options...
retired00 Posted June 19, 2007 Report Share Posted June 19, 2007 when i turn on A/C a squeaking begins and continues until u turn it off1999 rx 300 with 108K miles looks like one belt on entire engine ? and its tight as a guitar string any help out there? If it's still the original, time for a new belt. Even if it is newer, it could be glazed and no longer pliable, causing the squeal. Quote Link to comment Share on other sites More sharing options...
