chc4 Posted June 7, 2007 Report Share Posted June 7, 2007 My passenger side front turn signal is out and the rear passenger-side signal is doing a 'fast blink'. Left blinkers are fine. The owners manual does not identify a bulb type for the front signal but does for the rear. The auto part store could not look it up either (for the front). Anyone have a clue which bulb to purchase? Quote Link to comment Share on other sites More sharing options...
kiki470 Posted June 30, 2007 Report Share Posted June 30, 2007 My passenger side front turn signal is out and the rear passenger-side signal is doing a 'fast blink'. Left blinkers are fine. The owners manual does not identify a bulb type for the front signal but does for the rear. The auto part store could not look it up either (for the front). Anyone have a clue which bulb to purchase? I had the exact same problem with the bulb, I pulled out the bulb and swapped sides and it worked fine that was about 3 months ago and it is still working. Quote Link to comment Share on other sites More sharing options...
kingomar Posted July 1, 2007 Report Share Posted July 1, 2007 My passenger side front turn signal is out and the rear passenger-side signal is doing a 'fast blink'. Left blinkers are fine. The owners manual does not identify a bulb type for the front signal but does for the rear. The auto part store could not look it up either (for the front). Anyone have a clue which bulb to purchase? I had the exact same problem with the bulb, I pulled out the bulb and swapped sides and it worked fine that was about 3 months ago and it is still working. the size of the front bulb is 7507. Should be at any auto parts store. if not, check online on ebay or something. Quote Link to comment Share on other sites More sharing options...
