Air Force Rascal Posted May 28, 2007 Share Posted May 28, 2007 Has anyone changed a connecting rod on their SC400..I hear that you can replace it by going thru the oil pan without taking the engine out of the car...has anyone done this..? Thanks for any help... Quote Link to comment Share on other sites More sharing options...
jzz30 Posted June 1, 2007 Share Posted June 1, 2007 if you do go through the bottom end you would need to take the crank out. these kinds of "in depth" repairs are easier if you just pull the motor. why do you want to take the rods out anyway? Quote Link to comment Share on other sites More sharing options...
Air Force Rascal Posted August 22, 2007 Author Share Posted August 22, 2007 if you do go through the bottom end you would need to take the crank out. these kinds of "in depth" repairs are easier if you just pull the motor. why do you want to take the rods out anyway?Had a bent rod...and your wrong about the crankshaft..the rod and piston came out just fine through the top after taking the head off...I know because I did it myself with the factory manual. Quote Link to comment Share on other sites More sharing options...
jzz30 Posted August 30, 2007 Share Posted August 30, 2007 no im not wrong you asked about taking it out through the oil pan. its impossible without taking the crank out... anyway how'd you bend the rod? Quote Link to comment Share on other sites More sharing options...
