SuperCoupe400 Posted May 24, 2007 Share Posted May 24, 2007 The stock tire size for the '93SC4 is 225/55/16. Will a 235/55/16 fit the wheel without any adverse effects? Not trying to do it to get a wider look (though it would be nice). I'm just looking at a set of tires on sale at that size, but not available in the stock size. Thanks Quote Link to comment Share on other sites More sharing options...
grnsc40095 Posted May 25, 2007 Share Posted May 25, 2007 SuperCoupe400, Use the link below to check for the results. It showed minor differences and should be fine, to purchase 235/55/16 tire size. http://www.1010tires.com/TireSizeCalculato...p?action=submit Quote Link to comment Share on other sites More sharing options...
SuperCoupe400 Posted May 25, 2007 Author Share Posted May 25, 2007 SuperCoupe400, Use the link below to check for the results. It showed minor differences and should be fine, to purchase 235/55/16 tire size.http://www.1010tires.com/TireSizeCalculato...p?action=submit Great link. Thanks. Quote Link to comment Share on other sites More sharing options...
mberrett Posted May 29, 2007 Share Posted May 29, 2007 SuperCoupe400, Use the link below to check for the results. It showed minor differences and should be fine, to purchase 235/55/16 tire size.http://www.1010tires.com/TireSizeCalculato...p?action=submit Great link. Thanks. I run 245 50zr 20's, you should be good to go Quote Link to comment Share on other sites More sharing options...
SuperCoupe400 Posted June 1, 2007 Author Share Posted June 1, 2007 I run 245 50zr 20's, you should be good to go Thanks, but my concern was whether or not the 235 tire width would still fit (safely) on the stock wheel (which is designed for a 225 width tire). I wouldn't want the tire bead popping off the wheel in a hard corner or anything. Quote Link to comment Share on other sites More sharing options...
jzz30 Posted June 3, 2007 Share Posted June 3, 2007 it will be fine but the tire will also be a tad taller on the sidewall Quote Link to comment Share on other sites More sharing options...
