Help, Sc Arthritis!
Lithium grease is your friend. Also, your door can be adjusted if it possibly has sagged down a little over time. And then you can replace/repair the hinge assy., but it is a pita.
The doors are nice & tight, no sag at all, however It's been raining alot and the lithium that was there may have been washed out. I'm going to Westmarine after work and picking up some marine grade white Lith.
Thanks for all the help.
:D
