Jpi Built Is300 459whp @18 Psi
JPI
Congrats to Greg Brown from South Lake, TX. Vehicle makes 459whp @ 18 psi. Here are the specs on it
JPI Turbo kit with 3" piping
T70 Turbo
440cc injectors
W58 tranny
RPS stage clutch
TT short block
ARP head studs
Custom JPI Head gasket
Modified stock flywheel
Custom JPI fuel rail and lines
PCS XFC with walbro in line pump and some special sauces
http://i135.photobucket.com/albums/q...g?t=1178054013
http://i135.photobucket.com/albums/q...g?t=1178054105
http://i135.photobucket.com/albums/q...g?t=1178054164
http://i135.photobucket.com/albums/q...g?t....g?t=1178054688
This is on the stock W58 tranny. Congrats to Greg again.
JPI
Were these numbers produced on stock internals? What dyno was it tested on? MAP, blow through or draw through set-up? Was the stock ECU remapped or was it tuned with a stand-alone system?
Not to flame you but those #'s seem low for that amount of boost. Don't get me wrong, those are great whp #'s!! I'm just really curious as to what octane yieled those #'s @ that level of boost...that car should be in the 500's
This is with stock timing. There are a lot more of tuning left but it's pointless for to make more and the tranny will let go.
JPI
So any updates on this project lately??
18 psi! man thats crapton of boost!!! have you dyno'd the car? you should post the dyno sheet so we can see it. I would like to see the power curve and how the torque is hitting also.
have you had any tuning issues to deal with? are you having any issues with planting all that power on the ground? I would really like to know, I was thinking about going with a centrifugal supercharger on mine, so I would like to hear you turbo experience to compare with.
