Breaking Wheel Studs Alot!
mr_goodwrench_06
8 studs
are the rims original toyota/lexus ones
do you have the proper nuts?
as they have a special tapered edge that toyota likes to use
that might be the reason they are breaking
go to the dealer and order one and look if there is a difference
i would say there is more pressure on that side of the car
which usually happens
another question
is are the studs long enough to get a good grip on the rims and nut
sometimes if they are shorter they will cause an increase in pressure near the end of the nut which has a very low threshold for pressure
are you usign spacers at all for the new rims?
No spacers, but the studs do not go all the way through the lug nut. I sorta thought this was wrong, but that is how I got it. My wife and I saw a set of chrome factory rims on a '98 GS (I think) that I wouldn't mind putting on, if I found a set. Maybe my rims are too thick, and I need longer studs. Any Idea where I could get them? I just keep buying stock Lexus studs.
Thanks,
Bill
they may have a longer set
the offset is bigger on the new rims causing more of it to be taken up by the rim and not the bolt
it should help relive the pressure
there should be a spacer kit from h and r since you are on one of the most popular bolt patterns
basically has newer longer bolts to go on the rims
but the spacer has flush fit nuts that recess into the spacer
it might work if they make it
and there is room for it under the fender
