Sc300 Thermostat Repalcement
Has anyone ever changed their own thermostat in a Sc300? I have a 92 and have removed the one bolt and one nut but the housing will not come off. Am I missing something? I don't want to force the housing and crack it.
the thermostat on the 92 sc300 is located on the lower passenger side of the block, just follow the lower radiator hose. its pretty simple really.
first drain the coolant
remove the lower hose clamp
remove lower hose from housing
remove thermostat housing (three nuts if i remember correctly)
remove old t-stat and o-ring
make sure to replace the o-ring on the t-stat
replace everything and top off coolant with a 50/50 mix
hope this helps
