2004 Ls430 Headlight Alignment
HankJ
Hello,
Is there an easy way to align my main and high beam highlites?
Unfortunatly, I killed Bambi on the road last week and had to have both light assemblies removed and replaced.
My LS430 have the mobile lights that adjust for body attitude and when rounding curves.
Thanks,
Hank B)
  • Like 1
I know that the owners manual has the instructions on the vertical adjustment, but does any one have the details and what the targets locations, dimensions etc ought to be?
Thanks
Hank
:cheers:
See the attached, make sure the engine is running whaile you do the adjustments. I found I needed a slightly longer than normal Phillips screwdriver to reach both adjustors.
Great! Thanks for the info!!!!
What manual did this come from, and where can I get one?
Hank
:cheers:
  • Like 1
HankJ
Hope someone got back to you before this, but the answer is simple. Check out the web site: techinfo.toyota.com
You have to register, but for a reasonable amount of money ($10 ro so) you can get access for 24 hours and download the maintenance manuals, etc.
