Navigation System Reset
  • 5 years later...
Does any one know how to reset a ES300 2002 Nav Sys. I get an error message that says can not read data check to see if DVD is correct.
You can try pulling the fuse for the radio/navigation system from the fuse panel for 5-10 minutes or can pull the negative terminal cable from the battery for 5-10 minutes. If you pull the battery cable you will lose some presets though, like radio and seat settings, etc.
2008 Lexus Reviews
First, the ten digit part number on the disc should be 86271-3303X; the last digit does not matter. If you have something else besides a -3303x then you have the wrong disc installed.
Second, did you select a different country in the LOADING TAB section hidden within the diagnostic screen? If YES, then you will have to buy a new or remanufactured navigation ECU. The part number is 86841-47020-OW.
Hope this helps.
