PDT Posted April 7, 2007 Share Posted April 7, 2007 Where is the engine air filter located on a 2001 LS 430 and how difficult is it to replace? Thanks Quote Link to comment Share on other sites More sharing options...
sheab Posted April 8, 2007 Share Posted April 8, 2007 Where is the engine air filter located on a 2001 LS 430 and how difficult is it to replace? Thanks air filter are ..very easy to replace .... im not sure where is located ls430 but here is some tip ... you seee a plastic pipe connected to .. ur engine block ... as you flow the pipe . you willl notice its changeing shape of it ... eigther round or square ... kida look big .. u will see a metel clip on top unlock the clip and there is ur filter ..ummmmmmmmm hope thats help Quote Link to comment Share on other sites More sharing options...
cardona6569 Posted April 8, 2007 Share Posted April 8, 2007 It has to be in the passenger side of the motor. It would look like a box or round shaped object measuring about one foot more or less. It will have some quick opening tabs, after those tabs you will see a square box with a plug that would be your maf sensor and the tubing it to go inside the engine. Also check the owners manual it may have a diagram of the servicing points. Go to Irontoad.com or to your local auto parts store and see what one filter looks like, or in the dealer when you go to buy the filter they will show you the diagram of where it is at. CPR Where is the engine air filter located on a 2001 LS 430 and how difficult is it to replace? Thanks Quote Link to comment Share on other sites More sharing options...
