mberrett 0 Posted March 29, 2007 Report Share Posted March 29, 2007 my 96 sc400 needs to have the passenger side door latch/lock assembly changed, the door handle rod slipped out; (broken rod clip;) and was bent donward when the window was lowerd, when I bent the rod back, it broke off, the door handle pull rod, is part of the door latch/lock, and cannot be replaced, you must replace, the entire assembly. of coarse the dealership wants over $500.00 for the work, the part goes for $280.00, any tips out there. Quote Link to post Share on other sites
option00002 0 Posted March 29, 2007 Report Share Posted March 29, 2007 FWIW...I just had the same issue arise with my passenger door. My tech is going to fix it Saturday and claims he can do it inexpensively. I will let you know the result. Quote Link to post Share on other sites
lexus082 0 Posted March 30, 2007 Report Share Posted March 30, 2007 I had a similiar problem. Could not open the door from the outside. Had to replace a little plastic called a outside door handle snap. It connected the rod to the outside handle. Part number for the passenger side door snap 69293-12050. Fixed it for about $6. But it didn't have anything to do with the lock or latch. Quote Link to post Share on other sites
grnsc40095 1 Posted March 30, 2007 Report Share Posted March 30, 2007 my 96 sc400 needs to have the passenger side door latch/lock assembly changed, the door handle rod slipped out; (broken rod clip;) and was bent donward when the window was lowerd, when I bent the rod back, it broke off, the door handle pull rod, is part of the door latch/lock, and cannot be replaced, you must replace, the entire assembly. of coarse the dealership wants over $500.00 for the work, the part goes for $280.00, any tips out there. 'mberrett', Post your part request to this guy, he might be able to help... Email me: if you need used cars, used parts, or rebuildable vehicles, a portion of the proceeds goes to clublexus.com. Thank you. Authorized CL Vendor Email: gazi.ali@gmail.com AOL IM: PL Gazi Paypal: gazi_ali@hotmail.com underscore("_") between gazi and ali Buy with confidence, check my feedback: http://sr1.clublexus.com/forums/showthread.php?t=119137 You can send him a PM (aliga), he is a member of this club too. GOOD LUCK! Quote Link to post Share on other sites
SuperCoupe400 1 Posted April 2, 2007 Report Share Posted April 2, 2007 I had a similiar problem. Could not open the door from the outside. Had to replace a little plastic called a outside door handle snap. It connected the rod to the outside handle. Part number for the passenger side door snap 69293-12050. Fixed it for about $6. But it didn't have anything to do with the lock or latch. This hasn't happen to me yet, but if/when it does, I hope it's as simple to repair as yours, lexus082. I just recently had to replace the entire exterior door handle assembly in my wife's Eclipse, and it was an absolute nighmare - having to remove the glass from the door. It took me 4.5 hours of !Removed! around to finally finish the job. I absolutely dread the day when I might have to do the same for the Lex. Quote Link to post Share on other sites
BadBob 0 Posted April 17, 2007 Report Share Posted April 17, 2007 my 96 sc400 needs to have the passenger side door latch/lock assembly changed, the door handle rod slipped out; (broken rod clip;) and was bent donward when the window was lowerd, when I bent the rod back, it broke off, the door handle pull rod, is part of the door latch/lock, and cannot be replaced, you must replace, the entire assembly. of coarse the dealership wants over $500.00 for the work, the part goes for $280.00, any tips out there. Same thing happened to me - the break and all. I took the bottom broken piece of the rod - now in the shape of a "U", drilled a small hole at the base of the "U", turned it upside down, drilled a small hole at the base of the top part of the rod just above the break point & screwed the two pieces together with a small sheet metal screw (kind of looked like a tuning fork). I then re-inserted the upside "U" part of the rod back into the locking mechanism in its original place (small hole with a spring loaded bar against the edge of the door) & clipped the top part of the rod back onto its place on the door handle. It has been over six months and it has worked like a charm (knock on wood). Quote Link to post Share on other sites
Netzarim 0 Posted February 5, 2008 Report Share Posted February 5, 2008 My passenger side door won't open at all.. At first it was just the inside handle not actuating anything, I figured I would look at it later... Well, should have looked sooner because now that outside handle has the same problem.:chairshot:.. The door is still shut... Any ideas on how to go about: A. opening the door B. repairing the handles Especially - opening the door! Lexus SC400 1992 Quote Link to post Share on other sites
twodmax 0 Posted February 5, 2008 Report Share Posted February 5, 2008 Wow must be door gremlings this week. It just happened to my 300/ I think the cold weather had something to do with mine. Passenger side opens from inside only. There are DIY on Club Lexus forum- might have to remove door panel:( Quote Link to post Share on other sites
VincyRay 0 Posted February 11, 2008 Report Share Posted February 11, 2008 Yeah - this happens to everybody... It seems as popular an issue as this is, somebody should rebuild them or make replacement rods... Anybody know of anything like that? Also - Interior Handles... If your's haven't broken yet, odds are they will. I know they're not that that expensive from the dealer ($50 when I had to replace one two years ago), but do you know of anyplace to get them? Quote Link to post Share on other sites
moe&michelle 0 Posted February 11, 2008 Report Share Posted February 11, 2008 i have the same problem, my drivers side door will not open from outside, the rod broke, went to lexus dismantlers, they want $150.00 for rod? any one have a cheaper solution? Quote Link to post Share on other sites
chung_wong 0 Posted October 19, 2008 Report Share Posted October 19, 2008 I had a similiar problem. Could not open the door from the outside. Had to replace a little plastic called a outside door handle snap. It connected the rod to the outside handle. Part number for the passenger side door snap 69293-12050. Fixed it for about $6. But it didn't have anything to do with the lock or latch. Quote Link to post Share on other sites
latenightmechanic 0 Posted November 26, 2008 Report Share Posted November 26, 2008 I had a similiar problem. Could not open the door from the outside. Had to replace a little plastic called a outside door handle snap. It connected the rod to the outside handle. Part number for the passenger side door snap 69293-12050. Fixed it for about $6. But it didn't have anything to do with the lock or latch. 1992 lesux sc400 door handle problem. Hello, I had a similar problem with the passenger side door. The door would not open from the outside, so I replaced the door handle snap. Now the door opens just fine from the outside, however, from the inside, I can't lock the door or open it (at least with the amount of force I was comfortable using). It seems to lock, but it must not be locking all the way, because I can open it right up from the outside. I must admit that when I was working on the door, I left the door handle attached to the panel hanging by those cables. Any advice? Thanks. Quote Link to post Share on other sites
Cwallbball10 0 Posted November 27, 2008 Report Share Posted November 27, 2008 You might have Overextended the cables. The lock and inside door latch both deal with those cables Quote Link to post Share on other sites
LC'sSC 0 Posted September 14, 2011 Report Share Posted September 14, 2011 my 96 sc400 needs to have the passenger side door latch/lock assembly changed, the door handle rod slipped out; (broken rod clip;) and was bent donward when the window was lowerd, when I bent the rod back, it broke off, the door handle pull rod, is part of the door latch/lock, and cannot be replaced, you must replace, the entire assembly. of coarse the dealership wants over $500.00 for the work, the part goes for $280.00, any tips out there. 'mberrett', Post your part request to this guy, he might be able to help... Email me: if you need used cars, used parts, or rebuildable vehicles, a portion of the proceeds goes to clublexus.com. Thank you. Authorized CL Vendor Email: gazi.ali@gmail.com AOL IM: PL Gazi Paypal: gazi_ali@hotmail.com underscore("_") between gazi and ali Buy with confidence, check my feedback: http://sr1.clublexus.com/forums/showthread.php?t=119137 You can send him a PM (aliga), he is a member of this club too. GOOD LUCK! Quote Link to post Share on other sites
Tizzal83 0 Posted September 7, 2020 Report Share Posted September 7, 2020 Hello . My driver door won't open from the outside. The window doesn't work either. I believe the handle is broken but the motor works. I can't find the regulator and door handle. Quote Link to post Share on other sites
