Recommended Service
I am about to hit 75000 miles on my '01 gs430.
Dealer says I need the recommended 75k service which varies from $250-340 depending on which dealer I called. I'm thinking on just flushing my coolant and doing an oil change (needed). The 75k service (trans flush (already did), a/c filter, check brakes, check undercarriage, "gas additive", etc..) seemed unecessary. Any opinions?
save your money, do the oil, check the air filter, the coolant(stick with toyota coolant), maybe the power steering fluid if needed and you should be fine. I think your fuel filter is a lifetime maintenance free part. if you're gonna get your car up might as well change your differential fluid too... oh yead top it all off with a little tree airfreshner and you're good to go.
