tofu Posted March 7, 2007 Share Posted March 7, 2007 My 95 LS400 air conditioning fan in front the condensor is not running when I turn on the air conditioning. The air is cold inside the car. Is there a fuse for this fan any where in the car? Quote Link to comment Share on other sites More sharing options...
Shelly'sLS400 Posted March 7, 2007 Share Posted March 7, 2007 Could be a couple of things. The relay for the fan could be bad. The fan motor could be bad. I think the A/C system has to build pressure before the fan turns on. Have you driven it for a while to see if the fan does start??? Bryan Quote Link to comment Share on other sites More sharing options...
LScott400 Posted March 8, 2007 Share Posted March 8, 2007 I don't know if '95 was different, but I remember changing a 30A fusible link in a '94 (looked like a big fuse, pink body with a clear window on top) to get a fan running again. The following is the section out of '94 manual (the "FAN H-Fuse" denoted in the upper right corner of the 1st page was the one I changed): electriccoolingfan.pdf Quote Link to comment Share on other sites More sharing options...
tofu Posted March 8, 2007 Author Share Posted March 8, 2007 I don't know if '95 was different, but I remember changing a 30A fusible link in a '94 (looked like a big fuse, pink body with a clear window on top) to get a fan running again. The following is the section out of '94 manual (the "FAN H-Fuse" denoted in the upper right corner of the 1st page was the one I changed): electriccoolingfan.pdf I think 95 and 94 are different, I can't see that Fan-H-fuse in my fuse box. My 95 only has 1 cooling fan for the AC and 1 cooling fan for the radiator. According to your attachment, it shows that 94 has 2 cooling fans for AC. Quote Link to comment Share on other sites More sharing options...
RFeldes Posted March 8, 2007 Share Posted March 8, 2007 That fan will not cut on until the condensor get's really hot. Normal. Quote Link to comment Share on other sites More sharing options...
tofu Posted March 8, 2007 Author Share Posted March 8, 2007 That fan will not cut on until the condensor get's really hot. Normal. OK! thank you for the info. Quote Link to comment Share on other sites More sharing options...
