buckyes300 Posted August 23, 2003 Share Posted August 23, 2003 Need to replace my bulb, what's the trick to removing the subwoofer cover that houses the brake light? My Haynes Camry manual shows tabs accesable through the trunk that release the cover. No such thing with my vehicle! Thanks, buckyes300 Quote Link to comment Share on other sites More sharing options...
m2pc Posted September 7, 2003 Share Posted September 7, 2003 Read that you remove the subwoofer assembly to access it. Search of brake light turned this up: http://us.lexusownersclub.com/forums/index...&hl=brake+light Quote Link to comment Share on other sites More sharing options...
laserron Posted September 11, 2003 Share Posted September 11, 2003 Hi, I don't know about a 98. On a 93 there are two clips that hold the front of the subwoofer cover down. Access is from the trunk. Use pliers to compress them and push up. the cover hinges from the rear (Glass holds rear down). You can then have access to the bulbs from the back seat. Be careful to use an exact replacement. The warning light will stay on otherwise. Good luck Quote Link to comment Share on other sites More sharing options...
HoeBag Posted September 12, 2003 Share Posted September 12, 2003 i have a 97 and have done this many times get on the back seat, look at the top housing, get a screwdriver or use your bare hands - pull up at the front and it should slide right out, then at the back will be a wire and a clip holding the harness down to the bulb assembly, then unclip it...now u have the subwoofer cover in your hands. turn socket counter clockwise and pull, then change bulb, now do reverse of what i just typed Quote Link to comment Share on other sites More sharing options...
Sunbeam Posted September 13, 2003 Share Posted September 13, 2003 On the 98 you just pull the housing (essentially a cover) of the brake light unit back (in the direction of the front of the car) and it unclips. Very easy. Quote Link to comment Share on other sites More sharing options...
