scrappyslexus Posted February 23, 2007 Share Posted February 23, 2007 Since the recall on the headlights I have been averaging a burnt light bulb every 6 months. Has anyone experienced similiar problems? Quote Link to comment Share on other sites More sharing options...
Jim_Chow Posted February 28, 2007 Share Posted February 28, 2007 Since the recall on the headlights I have been averaging a burnt light bulb every 6 months. Has anyone experienced similiar problems? Is this the recall on the '04 DRL's for being too bright? I think they just put a resistor in there, right? Are you using stock/OEM bulbs? The Japanense-made Koyo bulbs last a lot longer than bulbs one buys here. If you're using bulbs like Sylvania silverstars or high wattage bulbs, they only last 6 months tops. I'm running HID's in mine, vehicle wasn't subject to the recall. Quote Link to comment Share on other sites More sharing options...
scrappyslexus Posted March 2, 2007 Author Share Posted March 2, 2007 Since the recall on the headlights I have been averaging a burnt light bulb every 6 months. Has anyone experienced similiar problems? Is this the recall on the '04 DRL's for being too bright? I think they just put a resistor in there, right? Are you using stock/OEM bulbs? The Japanense-made Koyo bulbs last a lot longer than bulbs one buys here. If you're using bulbs like Sylvania silverstars or high wattage bulbs, they only last 6 months tops. I'm running HID's in mine, vehicle wasn't subject to the recall. I sill try the koyo bulbls. The sylvania silverstars were recommended. Thanks Quote Link to comment Share on other sites More sharing options...
hoser Posted March 2, 2007 Share Posted March 2, 2007 I sill try the koyo bulbls. The sylvania silverstars were recommended. Thanks I would think your recalled DRL's will allow the bulbs to last even longer. Quote Link to comment Share on other sites More sharing options...
Jim_Chow Posted March 3, 2007 Share Posted March 3, 2007 Are you talking about the high beam/DRL bulbs? Those should be the only ones affected by the recall. Your lows shouldn't matter. Did they splice on a resistor in series at the DRL relay in the engine compartment (little black box bolted to the inside wall just next to the air filter box). Do you see any splice job there? Quote Link to comment Share on other sites More sharing options...
scrappyslexus Posted March 3, 2007 Author Share Posted March 3, 2007 Are you talking about the high beam/DRL bulbs? Those should be the only ones affected by the recall. Your lows shouldn't matter. Did they splice on a resistor in series at the DRL relay in the engine compartment (little black box bolted to the inside wall just next to the air filter box). Do you see any splice job there? I see the box, the low beams are the ones that keep burning out. They also did not look as bright after the box was installed. Quote Link to comment Share on other sites More sharing options...
Jim_Chow Posted March 5, 2007 Share Posted March 5, 2007 Could you post a snap shot of your DRL relay box and any mods they made? The low beams shouldn't be affected by adding more resistance to the high beam chain. Can you see where they added the so-called resistor to reduce the DRL brightness? Is it a normal resistor with color bands that they spliced into the harness? What I'd really want to know is what color wires are they. This will reveal where they put it. I could then suggest how to modify it back to the original configuration, as I have the schematics in the factory electrical manual. Quote Link to comment Share on other sites More sharing options...
Jim_Chow Posted March 7, 2007 Share Posted March 7, 2007 It's ironic that you mention you have bulb problems after the DRL recall. My SM just called saying the recall applies to all LX's 98-05, and asked if I wanted it done. I declined. :) Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted March 7, 2007 Share Posted March 7, 2007 wearing gloves when you install your bulbs? Quote Link to comment Share on other sites More sharing options...
LXPearl Posted March 8, 2007 Share Posted March 8, 2007 I thought one of my bulbs wore out quick, but when I looked at it it was still good. Turns out the wiring just in back of the bulb had a break in it. The short wiring was replaced by Lexus and everything has been fine since. I do not have your problem with dull headlights and the DRL fix has been done. Quote Link to comment Share on other sites More sharing options...
scrappyslexus Posted March 9, 2007 Author Share Posted March 9, 2007 wearing gloves when you install your bulbs? Yes I thought one of my bulbs wore out quick, but when I looked at it it was still good. Turns out the wiring just in back of the bulb had a break in it. The short wiring was replaced by Lexus and everything has been fine since. I do not have your problem with dull headlights and the DRL fix has been done. That wire was also changed on my vehicle. Quote Link to comment Share on other sites More sharing options...
Jim_Chow Posted March 9, 2007 Share Posted March 9, 2007 What year are both of your vehicles? The SM told me that some years got a resistor, some years got an entirely new DRL relay. Quote Link to comment Share on other sites More sharing options...
scrappyslexus Posted March 10, 2007 Author Share Posted March 10, 2007 What year are both of your vehicles? The SM told me that some years got a resistor, some years got an entirely new DRL relay. 2000 Quote Link to comment Share on other sites More sharing options...
