Change Starter From The Rear?
Shadow
I will be dropping the transmission to replace the rear main seal and a couple other seals and is wondering if it is possible to also change the starter while the transmission is out? I am sure I can remove the starter bolts from the rear but can I remove the starter rearward?
NO sir,
The intake manifold woul have to come off.
JP Importz
