Shadow Posted February 22, 2007 Share Posted February 22, 2007 I will be dropping the transmission to replace the rear main seal and a couple other seals and is wondering if it is possible to also change the starter while the transmission is out? I am sure I can remove the starter bolts from the rear but can I remove the starter rearward? Quote Link to comment Share on other sites More sharing options...
JPI Posted February 22, 2007 Share Posted February 22, 2007 I will be dropping the transmission to replace the rear main seal and a couple other seals and is wondering if it is possible to also change the starter while the transmission is out? I am sure I can remove the starter bolts from the rear but can I remove the starter rearward? NO sir, The intake manifold woul have to come off. JP Importz Quote Link to comment Share on other sites More sharing options...
