portsmouthva Posted February 21, 2007 Share Posted February 21, 2007 Hello i just noticed by accident today my selector switch when put on power position does not display on the dashboard, any suggestions thanks i just used it sunday to suck up my friends Q45, and it worked fine Quote Link to comment Share on other sites More sharing options...
larryp Posted February 21, 2007 Share Posted February 21, 2007 Not to state the obvious - but - it's either the bulb in the dash or the selector switch is malfunctioning. If you are under full throttle, the power button won't make any difference since the shift points will be at their max RPMs any way. Power button adjusts shift points at less than full throttle to delay transmission shift until a higher RPM is reached. My guess would be a burned out bulb. Quote Link to comment Share on other sites More sharing options...
