Do you have a recommendation for a commonly available injector cleaner? One I used to use I can no longer find, it was a concentrate and only called for 2-3 ounces per tank. Just looking to put in a tank of gas and clean things out.
Seafoam at any parts store. $5-6 per can.
Great, thanks for the referral--I had read about Seafoam on the site but did not realize it was for injectors too.
Just a testimonial for Sea Foam Injector Cleaner. IT WORKED GREAT! I had a persistent check engine light, change a left bank O2 sensor but still had the CEL, maddening after $245 was downt he drain at the repair shop (I had not seen the posts on how easy it is to repair that myself!) Anyway, poured Sea Foam in the gas tank and four or five short errands later the CEL went off, so must have just been a stuck injector. I am a big fan now--thanks for the recommendation guys!
