pakattack Posted February 8, 2007 Share Posted February 8, 2007 hey guys i just recently purchased a 1998 lexus gs300 so im pretty new to this car (owning a celica before this) anyways i wanted to change the tailights to the clear and red LED's off like ebay... link to tailgihts ----> http://cgi.ebay.ca/98-05-LEXUS-GS300-JDM-L...1QQcmdZViewItem i was wondering how hard it is to replace the taillights...can somoen give me isntructions or direct me to some instructions (also does nebody know nething bout these tailghts, like how the fit, perform etc, im scared of ebay but they seem pretty legit) thanks alot Quote Link to comment Share on other sites More sharing options...
slate67 Posted February 9, 2007 Share Posted February 9, 2007 hey guys i just recently purchased a 1998 lexus gs300 so im pretty new to this car (owning a celica before this) anyways i wanted to change the tailights to the clear and red LED's off like ebay... link to tailgihts ----> http://cgi.ebay.ca/98-05-LEXUS-GS300-JDM-L...1QQcmdZViewItem i was wondering how hard it is to replace the taillights...can somoen give me isntructions or direct me to some instructions (also does nebody know nething bout these tailghts, like how the fit, perform etc, im scared of ebay but they seem pretty legit) thanks alot I have taken the lenses off 2 times to replace rear end bulbs. I do not have pictures but there are 3 bolts on the rear lens. Two are accessed from behind semicircular caps on the body just outside the weatherstripping that seals the trunk. They pry out with a flat blade screwdriver but do not force or the caps will become dented. You can remove the 2 nuts once they are exposed. The 3rd bolt is accesses from inside the trunk. It is covered by a plastic cap that twists off (reminded me of the oil fill cap when removing- quarter twist and pull out). The nut is accessed from here (deep socket is necessary. When the 3 nuts are removed the lens pulls off the body. If you drop the inside nut inside the trunk liner, don't freak out. It lands up in the body well on the side under the trunk liner. Can't tell you about the lenses but good luck. It's an easy procedure. Quote Link to comment Share on other sites More sharing options...
InspiredGS Posted February 10, 2007 Share Posted February 10, 2007 http://us.lexusownersclub.com/forums/index...showtopic=33444 Quote Link to comment Share on other sites More sharing options...
