DRAGUNOV Posted February 8, 2007 Share Posted February 8, 2007 ok so i removed the cluster to change some light bulbs and when i put everything back together my air bag light is on. i extracted code 22 which is warning light malfunction. has any one ran in to this problem? i have searched and found nothing. i tryed resetting the light but it wont go out any insight would be great thanks Quote Link to comment Share on other sites More sharing options...
dcfish Posted February 8, 2007 Share Posted February 8, 2007 ok so i removed the cluster to change some light bulbs and when i put everything back together my air bag light is on. i extracted code 22 which is warning light malfunction. has any one ran in to this problem? i have searched and found nothing. i tryed resetting the light but it wont go out any insight would be great thanks It sounds like you forgot to disconnect your neg. battery terminal before removing the cluster. Bummer There is a thread on CL discussing this dilemma. Try searching there forums. Quote Link to comment Share on other sites More sharing options...
DRAGUNOV Posted February 8, 2007 Author Share Posted February 8, 2007 ok thanks where is CL do you have a link? Quote Link to comment Share on other sites More sharing options...
dcfish Posted February 8, 2007 Share Posted February 8, 2007 ok thanks where is CL do you have a link? www.clublexus.com Quote Link to comment Share on other sites More sharing options...
