option00002 Posted February 7, 2007 Posted February 7, 2007 Can someone recommend a Timing Belt kit? What have others done? Do you need everything found in a kit? Any help is appreciated. :)
92Lex Posted February 7, 2007 Posted February 7, 2007 Timing belt, water pump, camshaft seals, (front) crankshaft seal, upper and lower timing belt idler pulley, hydraulic tensioner, thermostat and coolant. You probably should consider replacing these parts while you're at it.... spark plugs, distributor caps, distributor rotors and spark plug wires.
TexasComputerMan Posted February 7, 2007 Posted February 7, 2007 Everything that 92LEX said is what I did to my 1992 SC400 a year and 1/2 ago and it has run great since. I also bought all Lexus parts, even though they were a little more expensive. I have never regretted it.
dcfish Posted February 7, 2007 Posted February 7, 2007 Everything that 92LEX said is what I did to my 1992 SC400 a year and 1/2 ago and it has run great since. I also bought all Lexus parts, even though they were a little more expensive. I have never regretted it. I would stay with OEM parts. This is no time to put aftermarket parts in your lex.
option00002 Posted February 7, 2007 Author Posted February 7, 2007 I know at one point I saw a TBelt kit for approx $550 which included tensioners and the like. Shall I assume this is what you are referring to as aftermarket and that I should purchase the parts from the stealership? :cries: Thanks
dcfish Posted February 8, 2007 Posted February 8, 2007 I know at one point I saw a TBelt kit for approx $550 which included tensioners and the like. Shall I assume this is what you are referring to as aftermarket and that I should purchase the parts from the stealership? :cries: Thanks You should purchase the parts online and have a reputable mechanic do the labor. irontoad.com, lexuspartsonline.com, sewelllexus.com, autopartswarehouse.com.... and the like. Ask for quotes on OEM parts and go with the least expensive. ;)
option00002 Posted February 8, 2007 Author Posted February 8, 2007 I know at one point I saw a TBelt kit for approx $550 which included tensioners and the like. Shall I assume this is what you are referring to as aftermarket and that I should purchase the parts from the stealership? :cries: Thanks You should purchase the parts online and have a reputable mechanic do the labor. irontoad.com, lexuspartsonline.com, sewelllexus.com, autopartswarehouse.com.... and the like. Ask for quotes on OEM parts and go with the least expensive. ;) Thank you, That is just what I will do. Thank you for the links. I have a great tech to do the work I was just trying to buy the supplies as cheap uggh I mean as inexpensively :P as possible.
dcfish Posted February 8, 2007 Posted February 8, 2007 I know at one point I saw a TBelt kit for approx $550 which included tensioners and the like. Shall I assume this is what you are referring to as aftermarket and that I should purchase the parts from the stealership? :cries: Thanks You should purchase the parts online and have a reputable mechanic do the labor. irontoad.com, lexuspartsonline.com, sewelllexus.com, autopartswarehouse.com.... and the like. Ask for quotes on OEM parts and go with the least expensive. ;) Thank you, That is just what I will do. Thank you for the links. I have a great tech to do the work I was just trying to buy the supplies as cheap uggh I mean as inexpensively :P as possible. Your Welcome... You owe me a beer
dcfish Posted February 8, 2007 Posted February 8, 2007 No, you owe me a beer. I've been waiting DC I'm first in line...........................
