Dr.Gee Posted February 5, 2007 Share Posted February 5, 2007 Mine seemed to quit working all of a sudden :cries: how do i check to see if it is turned on. I am currently without manual. Quote Link to comment Share on other sites More sharing options...
denslexusgx470 Posted February 6, 2007 Share Posted February 6, 2007 How do you know that it stopped working? Quote Link to comment Share on other sites More sharing options...
DavidCHurd Posted March 6, 2007 Share Posted March 6, 2007 Mine seemed to quit working all of a sudden :cries: how do i check to see if it is turned on. I am currently without manual. Make sure that you did not inadvertenly push your center differential disconnect button. If you did the TC light will go off, but the 4 x 4 with the 'x' in the middle in red light will be on. Quote Link to comment Share on other sites More sharing options...
Dr.Gee Posted March 7, 2007 Author Share Posted March 7, 2007 Mine seemed to quit working all of a sudden :cries: how do i check to see if it is turned on. I am currently without manual. hard corner+snow+drift=usualy kicks in Quote Link to comment Share on other sites More sharing options...
DavidCHurd Posted March 7, 2007 Share Posted March 7, 2007 Mine seemed to quit working all of a sudden :cries: how do i check to see if it is turned on. I am currently without manual. hard corner+snow+drift=usualy kicks in Seems to be operating normal as that is when it should kick in when one wheel or the other might loose tracdtion. If you are in snow and wnat to pull evenly at slow speed, push in your center differential disconnect and that will add positraction to the rear wheels. Did you ever get an operators/owners manual? I have three (3) and would be happy to send you one of mine. I was hoping to get a shop service manual and was sent two operators manuals. I only need one. Quote Link to comment Share on other sites More sharing options...
