cj100 Posted February 5, 2007 Share Posted February 5, 2007 has anyone added steel brake lines? does it make much of a difference? Quote Link to comment Share on other sites More sharing options...
Rookie Posted February 12, 2007 Share Posted February 12, 2007 has anyone added steel brake lines? does it make much of a difference? I've heard of quite a few folks doing it. I don't think any of them would conclusively say it made a substantial difference in regards to braking. The guys that do a lot of off roading like to have stainless, and as a result of a lift, need to change out anyways in order to make them a little bit longer. Quote Link to comment Share on other sites More sharing options...
dougjohn2 Posted February 13, 2007 Share Posted February 13, 2007 it won't make a huge difference. you might get better performance and more likely better brake pad life by using 1998 model year LX 470 brake pads for your front brake pads. they just fit and the pads are way thicker than the stock LX 450 pads. Quote Link to comment Share on other sites More sharing options...
zentoichi Posted May 1, 2008 Share Posted May 1, 2008 Check out the Ih8tmud.com website. They are recommend changing the front rotors and pads to the 100 series style. Not just pads but rotors too. I'll be doing my soon and will post some pics later. Quote Link to comment Share on other sites More sharing options...
Rookie Posted May 2, 2008 Share Posted May 2, 2008 Check out the Ih8tmud.com website. They are recommend changing the front rotors and pads to the 100 series style. Not just pads but rotors too. I'll be doing my soon and will post some pics later. I've seen the same thing on there about replacing the rotors when you replace the pads. Not sure I understand the need for that. I've had the 100 series pads on the stock rotors for 30k with no problems and lots of wear left. I think those guys can be a little over the top on replacing stuff, which is fine if you've got extra money floating around and just want all new stuff. If so, why stop there... get new calipers, master cylinder and brake booster. Regards, Rookie Quote Link to comment Share on other sites More sharing options...
ellieoh Posted June 19, 2008 Share Posted June 19, 2008 has anyone added steel brake lines? does it make much of a difference? I bought rotors and pads from www.sleeoffroad.com as recommended by an LX450 owner. The difference was an marked improvement compared to the OEM offering. Quote Link to comment Share on other sites More sharing options...
dougjohn2 Posted November 1, 2008 Share Posted November 1, 2008 Check out the Ih8tmud.com website. They are recommend changing the front rotors and pads to the 100 series style. Not just pads but rotors too. I'll be doing my soon and will post some pics later. okay - let's clarify this a bit... this should read -- new 100 series brake pads with new 80 series rotors. not new 100 series brake pads with new 100 series rotors. the 100 series brake pads would be the ones used on 98 and 99 LX 470/Land Cruisers Quote Link to comment Share on other sites More sharing options...
