Cornering Lamp Bulb?
csufpk
Hey everyone, I'm new to the board. Just picked up a clean 92 SC400 recently and noticed that the left corner lamp didn't light up when I turned on the left turn signal. I found the part number but is an alternative solution to buying the bulb at the dealership? I have searched and can't find the exact bulb type it uses unless it's special just for Lexus cornering lamps.
csufpk, Found this on info on clublexus.com for a '94 Sc400 here is the link:
http://www.clublexus.com/forums/showthread...lb+corner+light
*You can find this corner bulb 27w 1156 at any auto store*
Following provided by:NYLexSC
Low Beams : 55w HB4/9006
High Beams: 65w 9005
Cornering Lights (located on the bottom of the bumper on each side, only light up with turn signals): 27w 1156 filament bulbs
Parking lights/city lights (located next to the low beam projector): 5w 168/194 wedge bulb
Turn Signals: 1157 filament bulbs
Amber Sidemarkers: 5w 168 bulb I THINK, not positive.
