5 Indicators Went Off At The Same Time
thdoan
My friend's 2005 RX330 2WD sometimes suddenly has all 5 following indicators (VSC, Trac Off, Brake, ABS, tire pressure indicators) lit up at the same time, and stay on until she shuts down and restart the engine. Tires pressures are OK. I am thinking about faulty ABS sensor but not sure. Any help is appreciated. :wacko:
TD
Does it happen when it is raining?
I had the same thing on my 01 300. Apparently the slipping belt in wet weather was causing it.
The last time the indicators went off, it was cold, not raining. I wonder how the slipping belt can trigger those indicators ?
