Well my gears in the Power antenna are stripped and I need a new one. I found a new OEM version for $215. I started to search for a 1992 Camry part and it is HALF!
Will it work??
Are you sure it's not just the mast that is broken instead of the entire assembly?
Yup, took it apart and the gear that touches the motor has been shortened over the years...It does not fit tight anymore..
