Door Trim Removal Of A 1993 Lexus Es300
firer
can someone tell me how to remove the inside d/s rear door trim in order to get to the window hardware. i went to lower the rear window and the glass fell all the way down. ive noticed its got several plastic panel/trim retainers all around the door trim but i cant seem to remove them without breaking the retainers themselves. is there a trick to removing these plastic retainers.
thanks in advance, rey
pull up the carpet in the handle and there is a screw under it.
thanks sk, but the problem im having is removing the plastic panel/trim retainers all around the door trim panel. when i try to pry and pull them out they are breaking.
They are old and need to be replaced not a big problem and easily replace.
thanks sk, i will let you know how i fair. by any chance do you know were i can get d/s rear window regulator without having to buy the motor. the dealer is charging $504.00 for the regulator and motor. they wont sell them seperately.
