rich21 Posted January 6, 2007 Share Posted January 6, 2007 when im driving i hear a squeeking noise coming from the passenger rear wheel. at times while im slowing down to a stop i hear like a metal grinding noise. i shook the wheel and theres a little bit of play in it. how can you tell if its the hub bearings. would i be able to do it myself or should i have a mechanic do it? how much would it cost to have a mechanic do it? thanks for any replies Quote Link to comment Share on other sites More sharing options...
92Lex Posted January 6, 2007 Share Posted January 6, 2007 You sloudn't be able to feel any "play" in the hub. If you've kicked your hub, u might as well DIY n replace the bearing. At home diagnostic...might as well at home fix it. Quote Link to comment Share on other sites More sharing options...
rich21 Posted January 7, 2007 Author Share Posted January 7, 2007 is it hard to diy? how should i go about doing it? is there a site that i can go on to see how to do it? Quote Link to comment Share on other sites More sharing options...
92Lex Posted January 7, 2007 Share Posted January 7, 2007 If you plan on doin' it yourself then subscribe to TIS. It's your friend at times like this. Quote Link to comment Share on other sites More sharing options...
jzz30 Posted January 8, 2007 Share Posted January 8, 2007 if you have confidence in taking ball joints off then go for it but if you dont then i would leave it to a pro. i did mine but it was a big pain to get the hubs off!! not to mention my breaker bar broke after trying to take off the axle nut! Quote Link to comment Share on other sites More sharing options...
rich21 Posted January 8, 2007 Author Share Posted January 8, 2007 when i felt that i had a little play with the wheel i took it off along with the caliper and rotor. i turn the akle nut to the right and it was a little loose. now am i making the right diagnosis here with the nosie and all? i took it to a mechanic and he said because of the play in the wheel and noise that its the bearings. Quote Link to comment Share on other sites More sharing options...
92Lex Posted January 8, 2007 Share Posted January 8, 2007 You shouldn't be able to turn the axle nut by hand. Tighten that first and see if the problem still persist. Quote Link to comment Share on other sites More sharing options...
rich21 Posted January 8, 2007 Author Share Posted January 8, 2007 i did and the nosie got a little worse Quote Link to comment Share on other sites More sharing options...
jzz30 Posted January 9, 2007 Share Posted January 9, 2007 when you lift the car up are you able to move the wheel side by side with your hands? if so the bearing is toast! Quote Link to comment Share on other sites More sharing options...
rich21 Posted January 10, 2007 Author Share Posted January 10, 2007 if i were to put one hand on top and the other on the bottom i can feel play in the wheel. should that explain the axle nut being loose? Quote Link to comment Share on other sites More sharing options...
92Lex Posted January 10, 2007 Share Posted January 10, 2007 Usually on cars with defective hub bearings, the nut is still on tight. If the nut is tight and you're still getting play, you should replace the hub bearing. Quote Link to comment Share on other sites More sharing options...
jzz30 Posted January 10, 2007 Share Posted January 10, 2007 the axle nut should not affect the wheel being able to move around since the bearing is a press fit. although under continuous load the axle nut being too loose could and will play a role but these nuts are torqued at over 200 ft-lbs so i doubt they came loose and then messed up the bearing. when my bearing went out the nut was tight and like i said my breaker bar died trying to take the nut off. most likely the nut became loose as a result of the bearing. either way you will need to buy a new inner hub. Quote Link to comment Share on other sites More sharing options...
rich21 Posted January 10, 2007 Author Share Posted January 10, 2007 shopuld i tighten the nut? how much can it all cost from a mechanic? i got a price of 220 just to replace the bearings. is that a good price? Quote Link to comment Share on other sites More sharing options...
jzz30 Posted January 11, 2007 Share Posted January 11, 2007 that sounds good if its both sides because it cost me 50 a piece to get the bearings pressed out and in. so thats half already. Quote Link to comment Share on other sites More sharing options...
rich21 Posted January 11, 2007 Author Share Posted January 11, 2007 actually thats only one side. should i tighten the axle nut? Quote Link to comment Share on other sites More sharing options...
