How Do I Know If I Have A Faulty Starter?
Grandpa
 Share
The first thing is to determine the state of the battery. Turn the headlights on high beam. Should be a very white light. If so, and trying to start does not produce engine rotation, then what noise does starting produce. If a click, loud or quiet, then more than likely the starter contacts have become fried.
If the headlights are dim, or orange or yellow in colour, then a good battery should be tried. The little battery packs don't impress me.
hrmm, it's clicking, but my headlight is also very dim
sometimes it doesn't click, it sort of chirps.....
I may have to remove the battery and take it to autozone... do i just remove the little nuts that hold onto the clamp?
Remove the negative terminal first, and when installing hook the negative up last.
There is a hold down bracket that you then remove and lift out the battery. Sounds like it won't pass a load test. Get a good battery, specific to the make model year of your car. Don't buy a "one size fits many" type.
It may be possible to charge your battery, but if it's more than four years old by the sticker just get a new one.
 Share
