Water Leak
300SC
Ive got a water leak in the 93 SC300 on the pass. side by the kick panel. When you open the door, you can see where the water was running down. There is also water in the pass side a pillar when I pulled that off. I replaced the weather sripping around the door opening, the piece that goes all the way around. But it leaked again. Can you guys think of any other things to check/ replace? Maybe the shorter piece of weather stripping that goes around the door opening?
