hil400 Posted January 2, 2007 Share Posted January 2, 2007 I did a search and it appears it is a reverse thread. Does anyone know if that is correct? I am trying to change my timing belt and I have having a hard time getting the bolt off. Thanks. Quote Link to comment Share on other sites More sharing options...
swordfish Posted January 2, 2007 Share Posted January 2, 2007 incorrect, it is not reverse thread. Go to lexls.com and loook at the tutorial for easiest way to do job. I did this and it worked a treat. cheers swordfish Quote Link to comment Share on other sites More sharing options...
hil400 Posted January 2, 2007 Author Share Posted January 2, 2007 incorrect, it is not reverse thread. Go to lexls.com and loook at the tutorial for easiest way to do job. I did this and it worked a treat. cheers swordfish Thanks for the reply. At least I am turning it the right way! I do not have an impact gun and cannot find a way to hold the pulley still so I can crank on the breaker bar. Any suggestions? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
lenore Posted January 2, 2007 Share Posted January 2, 2007 Try buying a rubber strap wrench to hold the cranshaft pulley, they work great and can be purchased at Harbor Freight tools or Sears or any good tool store for less than $20. Quote Link to comment Share on other sites More sharing options...
swordfish Posted January 3, 2007 Share Posted January 3, 2007 i just did it the easy way they show on lexls.com, put the breaker bar on and place it against floor and hit the starter quickly once, works a treat. swordfish Quote Link to comment Share on other sites More sharing options...
crazimofo Posted January 3, 2007 Share Posted January 3, 2007 hoo swordfish..thats sum gangsta *BLEEP*..good job :) Quote Link to comment Share on other sites More sharing options...
hil400 Posted January 11, 2007 Author Share Posted January 11, 2007 Try buying a rubber strap wrench to hold the cranshaft pulley, they work great and can be purchased at Harbor Freight tools or Sears or any good tool store for less than $20. Thanks, tried that and could not keep the pulley still would not come off. I do not know if they really torqued it on. i just did it the easy way they show on lexls.com, put the breaker bar on and place it against floor and hit the starter quickly once, works a treat. swordfish I was worried about trying that as it is an interference engine and I was scared of messing up the timing marks. I tried a PEP BOYS Goodyear 200 ft/lb cordless impact- no movement just bad smells coming from the gun So, I got a DeWalt impact and it came right off. Thanks for the replies. Quote Link to comment Share on other sites More sharing options...
