imfauxreal Posted December 27, 2006 Posted December 27, 2006 1992 SC300 When I start in the morning, when engine is still cold the idle goes up and down, but when its already in heat, it disappears I notice that I dont have the Idle up when you start the car when its cold If there is a sensor on this, where is it located?? Thanks for the one who will reply :)
glenn2726 Posted December 28, 2006 Posted December 28, 2006 Hi, check my reply to Applejacks idle problem, sounds like yours is the same, it's the Idle Air Control Valve located on the front of your engine, it controls the amount of vacuum your engine needs to run smoothly....
imfauxreal Posted December 29, 2006 Author Posted December 29, 2006 try check your ecu temp sensor Where is the ECU temp located??? Thanks super :)
jzz30 Posted December 30, 2006 Posted December 30, 2006 its on the radiator towards the bottom where the drain valve is. the resistance should read 1.48-1.58 ohms at 80 degrees C
imfauxreal Posted December 30, 2006 Author Posted December 30, 2006 its on the radiator towards the bottom where the drain valve is. the resistance should read 1.48-1.58 ohms at 80 degrees C Thanks A lot :D
