Want To Know The Actual Speed
95whitels
hi guys,
I have 1993 3vzfe es300 with 4 speed auto. I think my speedometer is not accurate. im cruising at 80km/hr at 2000rpm on highway. i need information from you guys about what is your cruising speed in km/hr on highway at 2000rpm and 2500rpm?
many thanks
Why don't you do the math yourself???
Come on bro, there's like several calculators on the first page of google lol!
2000rpm in 4th with the torque convertor locked = 52.54139908899227mph
2500rpm in 4th with the torque convertor locked = 65.67674886124034mph
6750rpm in 4th with the torque convertor locked = 177.3272219253489mph
7100rpm in 4th with the torque convertor locked = 186.52196676592257mph
You sure do drive pretty damn slow! :lol:
No problem.
It's not rpm that determines it, it's engine load. So don't worry if you're use to the newest v6/tranny combinations being 500rpm or so lower than ours.
After a point. The more you gear them down, the bigger the load on the engine, the more fuel it'll use anyways.
It's a balance. If aint probably aint loosing 1-2 mpg by not running lower.
