daovang Posted December 9, 2006 Share Posted December 9, 2006 I was driving up I85 from Concord, NC...35 miles later... As I got within a half mile of my exit I felt my transmission downshift to third gear (I think). To counteract to the lost of speed I increased throttle and notice a slight increase in RPM, but a second later my RPM was at 0 and engine dead. Does anybody know what could of happened? My engine had a slight burnt plastic smell, no popping noise from engine were audible, nor was there any visible oil/coolant leakage. It was dark and I couldn't do a full check but will return tomorrow to check fully. Thanks in advance for the diagnoses. ~daovang Also, three days ago my coolant mysteriously leaked massively. My brother refilled it and told me it had stopped. The source of leakage is still unknown. And today it died. Quote Link to comment Share on other sites More sharing options...
juno_reaction Posted December 9, 2006 Share Posted December 9, 2006 Although I can't give you any advice as I'm not a mechanic of any sort, I can safely assume that your scenario is probably my biggest fear. Quote Link to comment Share on other sites More sharing options...
blk_on_blk Posted December 10, 2006 Share Posted December 10, 2006 Yeah, that's my biggest fear, too.... and it's happened to me in other vehicles. I'm no mechanic either, but what it sounds like is something let go and caused an electrical short. The transmission is controled by the ECU on the 95 (as far as I know), so if something went weird with the ECU, it might have triggered your tranny to kick down a gear... and then the ECU might have gone kaputz right after and shut the engine down. If you had a mysterious coolant leak, you may have sprayed coolant onto an electrical part causing it to short out and shut everything down. Let us know what you find... I hope it's not too $$$ Quote Link to comment Share on other sites More sharing options...
jeff01 Posted December 14, 2006 Share Posted December 14, 2006 Yeah, that's my biggest fear, too.... and it's happened to me in other vehicles. I'm no mechanic either, but what it sounds like is something let go and caused an electrical short. The transmission is controled by the ECU on the 95 (as far as I know), so if something went weird with the ECU, it might have triggered your tranny to kick down a gear... and then the ECU might have gone kaputz right after and shut the engine down. If you had a mysterious coolant leak, you may have sprayed coolant onto an electrical part causing it to short out and shut everything down. Let us know what you find... I hope it's not too $$$ What happens when you turn the key? Quote Link to comment Share on other sites More sharing options...
monahans Posted December 18, 2006 Share Posted December 18, 2006 I have had this experience before in an es 250. First it was a sensor in or near the distributor. Plastic case just gave way. My car would crank but would not start. Second time it was the wire from the distributor to the coil (located right next the battery) that corroded and came apart. Quote Link to comment Share on other sites More sharing options...
