Redline - 03 Is300
El Toro
WOW this is the kind of question some one with very little maturity would ask.
If i get this right you want to know how to make your engine explode before it is ready so you can drive faster or make more noise ????
You have a straight 6 it is made by design not to go high into the rpm's as it would snap the crank.
In all seriousness you need to replace the internals to be able to have a higher redline. Which is why it is caused redline for being the last possible chance of maintaining the motor at that level.
