Climate Control Min/max Temp
DanW
 Share
I searched the forum but didn't find anything about this...
What are the min and max temps that the Climate Control unit in a 1992 ls400 can just to?
Like everyone else my lcd is shot, I would like to press the down arrow a bunch of times, then count up to where I want to be. I assume this is possible, I've never actually seen on that works!
Thanks
My display ain't too great either.
Low temp - 65 deg
High temp - 85 deg
Running completely to one end or the other actually goes
one step further, into 'Max'. That's full bore each direction,
the temp sensor is disabled, the system will just keep pumping as
hard as it can.
Low temp - 65 deg
High temp - 85 deg
hard as it can.
Thanks, great info. Aside from the LCD it seems to work ok. Maybe I'll fix it someday.
 Share
