Removing Headlight/fog Switch
None, it has to be removed.
Why do you need to take it out?
You might be able to access some of the screws once you pull off the plastic shield.
well because i think my switch is the problem why my fogs are not working, so im going to a junk yard tommarow and picking up the whole headlight/fog switch and doing a direct replacement
