Results Of My Wheels Upgrade!
breakilla
post-29629-1159132672_thumb.jpgNew Mod: wheels upgrade from 16 inches to 19 inches.
245/35/19 in the front.
275/30/19 in the rear.
offset: +38 i believe.
tires: toyo proxes T1R.
Wheels: HP Design *Lightning*
:) no problems with high speeds. wheels do not shake the steering wheels.
Suprisingly the ride did not change to much. No Rubing or No turning problems. The only thing i might need to do is drop it 1 inch. The Toyo tires are very quiet and responsive. I Did loose a little bit of power of lunges. Will do the Torque Convertere next. followed by headers and mufflers.
The suspension system is still stock.
Over all I think 19 inches are the perfect fit for the SC400.
  • 6 months later...
Nice! I think you should drop the front 1.5 in. and the rear 1in. to give it that agressive look. That would be perfect!! :cheers:
