Walt in Asheville Posted August 20, 2006 Share Posted August 20, 2006 Hello All, My SC400 has developed a nasty little steering leak. I think I am going to try a leak sealer substance of some sort first. Id like to know what types you guys have used that will not screw up the system. My local Lexus / Toyota specialist shop took a look and said oh you need a new pump and reservior. That will be a 1000 plus bucks. I am contending with the Lexus Wallet to be picked image I think. Thoughts? Opinions? I definatly appreciate you guys and what I have learned here thus far. Thanks, Walt Quote Link to comment Share on other sites More sharing options...
95_SC400 Posted August 20, 2006 Share Posted August 20, 2006 Hello All, My SC400 has developed a nasty little steering leak. I think I am going to try a leak sealer substance of some sort first. Id like to know what types you guys have used that will not screw up the system. My local Lexus / Toyota specialist shop took a look and said oh you need a new pump and reservior. That will be a 1000 plus bucks. I am contending with the Lexus Wallet to be picked image I think. Thoughts? Opinions? I definatly appreciate you guys and what I have learned here thus far. Thanks, Walt Sorry to hear about your problem, i had something similar to this and was also told to replace a lot of parts. after taking it to a really good mechanic it turned out all i needed was a $5 replacement bolt. So make sure that you are definate about were the leak is coming from. Quote Link to comment Share on other sites More sharing options...
robinlow Posted August 20, 2006 Share Posted August 20, 2006 Hello All, My SC400 has developed a nasty little steering leak. I think I am going to try a leak sealer substance of some sort first. Id like to know what types you guys have used that will not screw up the system. My local Lexus / Toyota specialist shop took a look and said oh you need a new pump and reservior. That will be a 1000 plus bucks. I am contending with the Lexus Wallet to be picked image I think. Thoughts? Opinions? I definatly appreciate you guys and what I have learned here thus far. Thanks, Walt Sorry to hear about your problem, i had something similar to this and was also told to replace a lot of parts. after taking it to a really good mechanic it turned out all i needed was a $5 replacement bolt. So make sure that you are definate about were the leak is coming from. Got a rebuild PS pump for $145, clean everything out first as the hoses may be leaking. Quote Link to comment Share on other sites More sharing options...
CAheunga Posted August 20, 2006 Share Posted August 20, 2006 Mine leaked onto the alterator, which cost $800 to replace :cries: -- br. Quote Link to comment Share on other sites More sharing options...
AngelsAmongUs Posted August 21, 2006 Share Posted August 21, 2006 Leaking ps pump taking out the alternator is a very common thing with our sc4's. Quote Link to comment Share on other sites More sharing options...
lexus082 Posted August 21, 2006 Share Posted August 21, 2006 Also it is believed that the filter within the solenoid in the power steering rack can cause this leak. The filter which is a fine metal screen becomes clogged after time. I had this happen to my sc400, but I changed out the power steering pump, cleaned the solenoid screen, flushed out the power steering system, and also had to change out the alternator. And everything has been working great since then. Very common problem among these cars. Usually its just the power steering pump that will leak, but make sure its not within the high pressure hoses. There's a lot of info. on this topic. If you do find it just to be the power steering pump I wouldn't waste time with the leak sealer. I would just pick up a remanufactured power steering pump for approx. $150.00. I would also clean the screen when installing the new pump. Quote Link to comment Share on other sites More sharing options...
Walt in Asheville Posted August 21, 2006 Author Share Posted August 21, 2006 Okay a couple of questions then 1. How tough is it to replace this pump. 2. What do I do with disposing of the old fluid. 3. Is there anything I can screw up doing this? I am not a master mech Quote Link to comment Share on other sites More sharing options...
94BLKSC400 Posted August 22, 2006 Share Posted August 22, 2006 Are you SURE it is the pump? Mine leaked from the hose. New hose and thats it. (Except that the alternator took a dump 2 months later....) Quote Link to comment Share on other sites More sharing options...
LuckyApril7 Posted August 24, 2006 Share Posted August 24, 2006 I changed the power steering pump and alternator for $300 at my local mechanic. That includes labor. He uses remanufactured parts but they last just as long and i'v had it working over 2 years without a leak. Quote Link to comment Share on other sites More sharing options...
Walt in Asheville Posted September 9, 2006 Author Share Posted September 9, 2006 Actually my BIGGEST problem is finding a shop that I want to trust. The local Toyota specialist charges almost as much as the dealership for labor. And no loaner car or free wash. I changed the power steering pump and alternator for $300 at my local mechanic. That includes labor. He uses remanufactured parts but they last just as long and i'v had it working over 2 years without a leak. Quote Link to comment Share on other sites More sharing options...
robinlow Posted September 10, 2006 Share Posted September 10, 2006 Hello All, My SC400 has developed a nasty little steering leak. I think I am going to try a leak sealer substance of some sort first. Id like to know what types you guys have used that will not screw up the system. My local Lexus / Toyota specialist shop took a look and said oh you need a new pump and reservior. That will be a 1000 plus bucks. I am contending with the Lexus Wallet to be picked image I think. Thoughts? Opinions? I definatly appreciate you guys and what I have learned here thus far. Thanks, Walt My SC300 was leaking a little but my P/S was not working at low RPMs, I changed my connecters and hoses, and now, there is no more leak. I sprayed degreaser, cleaned everything, dry and nice. It had stayed that way for 2 weeks now. But my powersteering still does not work at low rpms. (need 2000 rpm to work) I checked my solenoid filter, but it seems to be working and they are new. (Came with my $500 hose) I have spent $600+ so far, and my leaking stopped by still no P/S at low speeds. Getting a remanufactured pump next. :( Quote Link to comment Share on other sites More sharing options...
