Barabus Posted June 2, 2006 Share Posted June 2, 2006 I have an AC fault on my new RX 350. Lexus Westminster replaced the compressor, but it reoccurred. In both instances it was fixed by turning the AC off then back on. The problem is we have to do this after most engine restarts. Lexus HQ has acknowledge a problem that it is working on. Does this sound familiar to anyone? Quote Link to comment Share on other sites More sharing options...
Linda C Posted June 3, 2006 Share Posted June 3, 2006 I have an AC fault on my new RX 350. Lexus Westminster replaced the compressor, but it reoccurred. In both instances it was fixed by turning the AC off then back on. The problem is we have to do this after most engine restarts. Lexus HQ has acknowledge a problem that it is working on. Does this sound familiar to anyone? No problem thus far with my RX350, but thanks for the alert. Sounds like it's just a matter of time if HQ is already working on a solution! Quote Link to comment Share on other sites More sharing options...
RMB350 Posted July 1, 2006 Share Posted July 1, 2006 I'm not having any issues with my 350 either, although I've only just recently hit 1000 miles.. Hopefully your problem will be isolated and corrected soon! At least you have a workaround to bypass it in the meantime.. Ron.. Quote Link to comment Share on other sites More sharing options...
Dave72 Posted July 11, 2006 Share Posted July 11, 2006 Yup - I have that problem - apparently down to a software glitch that they are working on fixing back in the factory (or so I've been told the past 3 times I've taken it in). I've had this fault since day 1, back in March. Generally happens on cold starts only, about 2/3 of the time. Very annoying. I'm going to give them a couple more months to fix it before kicking in the lemon law, since this will affect my ability to sell the car in the future... Quote Link to comment Share on other sites More sharing options...
Rx330driver Posted July 11, 2006 Share Posted July 11, 2006 what exactly is wrong with it? does it not start or is it just not cold? Quote Link to comment Share on other sites More sharing options...
Dave72 Posted July 12, 2006 Share Posted July 12, 2006 It's a message failure - the AC is fine, it pops up a message saying "Check Air Conditioner" on the Nav screen. The AC still works fine tho. Turning the AC off/on removes the message, as does turning the ignition off/on. Quote Link to comment Share on other sites More sharing options...
Rx330driver Posted July 12, 2006 Share Posted July 12, 2006 ohh, that happened to me one time, but it was during a rain storm, and i was going into deep puddles and that message popped up as well. Im guessing its a glitch in your system that is warning you without any water damage, as least i think thats when it comes up Quote Link to comment Share on other sites More sharing options...
Dave72 Posted July 13, 2006 Share Posted July 13, 2006 Apparently this is new to RX350s. Stevens Creek Lexus is seeing a number of these failures now. Between that, the Sirius Sat Radio which they still haven't been able to get working on models with RSE, and the numerous door & dash rattles (which convieniently disappear as soon as a tech gets in the car!), I'm less than happy with my $45k purchase.... Quote Link to comment Share on other sites More sharing options...
CJ9 Posted September 1, 2006 Share Posted September 1, 2006 Apparently this is new to RX350s. Having same problem with a new RX350 myself. On cold start, often AC light will blink, and no AC. Cycling AC off then back on solves the situation at the moment (no NAV system, so I don't get the message you all refer to) - CJ9 Quote Link to comment Share on other sites More sharing options...
bpowers Posted October 23, 2006 Share Posted October 23, 2006 I have an AC fault on my new RX 350. Lexus Westminster replaced the compressor, but it reoccurred. In both instances it was fixed by turning the AC off then back on. The problem is we have to do this after most engine restarts. Lexus HQ has acknowledge a problem that it is working on. Does this sound familiar to anyone? I have the same problem. Started a few days after I picked up the car in May. I took it in for service, and the loaner car did the same thing. They also wanted to replace the compressor - I told them that didn't make any sense. I have not received anything in writing from Lexus or my dealer, and have no estimate for when a fix will be available. I tried something today at the advice of my brother who worked for Delphi for 15 years. He suggested I pull out the fuse for the A/C - which is the equivalent of a "hard reboot". After pulling the fuse, I started the car and the A/C came on right away - something it had not done before. On a hot day it was particularly annoying in that I'd sit there and watch the Lexus name show on the nav screen, and then either I'd get air or the 'Check air conditioner" message. Maybe this solved the problem? I'll know in a few days as I typcially get the error 2/3 of the time. Quote Link to comment Share on other sites More sharing options...
n2tdk Posted November 14, 2006 Share Posted November 14, 2006 Going through another site I found a TSB that might cover this issue.... (AC004-06) Lexus Supports ASE Certification Page 1 of 2 Title: A/C LIGHT BLINKING Models: ’07 RX 350 Technical Service Information Bulletin October 13, 2006 AC004-06 Some customers may experience the A/C light blinking and/or a “Check A/C System” error message on the multi-display. Production changes to the A/C amplifier have been made to remedy this concern. 2007 model year RX 350 vehicles produced BEFORE the Production Change Effective VINs shown below. MODEL PLANT DRIVETRAIN PRODUCTION CHANGE EFFECTIVE VIN TMK 2WD JTJGK31U#70004858 RX 350 4WD JTJHK31U#72013500 TMMC 2WD 2T2GK31U#7C011001 4WD 2T2HK31U#7C018238 PREVIOUS PART NUMBER CURRENT PART NUMBER PART NAME QTY 88650–0E020 88650–0E021 Amplifier Assembly, Air Conditioner 1 OP CODE DESCRIPTION TIME OFP T1 T2 AC0007 R & R A/C Amplifier 0.4 88650–0E020 99 99 Applicable Warranty*: This repair is covered under the Lexus Comprehensive Warranty. This warranty is in effect for 48 months or 50,000 miles, whichever occurs first, from the vehicle’s in-service date. * Warranty application is limited to correction of a problem based upon a customer’s specific complaint. HEATING & AIR CONDITIONING Introduction Applicable Vehicles Production Change Information Parts Information Warranty Information A/C LIGHT BLINKING – AC004-06 October 13, 2006 Page 2 of 2 1. Disconnect the negative (–) battery terminal. 2. Remove the RH front door scuff plate. 3. Remove the RH cowl side trim sub-assembly. 4. Remove the instrument panel under cover sub-assembly. 5. Remove the glove compartment door assembly. 6. Remove the ECM. 7. Remove the air conditioner amplifier assembly. A. Disconnect the connectors, including the suspension control ECU connectors. B. Remove the 2 nuts retaining the air conditioner amplifier assembly/suspension control ECU bracket. 8. Remove the suspension control ECU from the bracket (w/ air suspension). 9. Reassemble in reverse order of disassembly. 10. Perform all necessary re-initialization procedures. Refer to the following TSIBs: TSIB No. PD006-06, “Initialization of Power Back Door During PDS” TSIB No. PD007-06, “Initialization of Sliding Roof During PDS” TSIB No. PD008-06, “Initialization of Power Window During PDS” Repair Procedure A/C Amplifier Quote Link to comment Share on other sites More sharing options...
Dave72 Posted December 3, 2006 Share Posted December 3, 2006 I had this problem - was bugging the hell out of me. Eventually the AC amplifier fix was made - works perfectly now. Quote Link to comment Share on other sites More sharing options...
Billsingle Posted November 2, 2019 Share Posted November 2, 2019 On 6/2/2006 at 7:03 PM, Barabus said: I have an AC fault on my new RX 350. Lexus Westminster replaced the compressor, but it reoccurred. In both instances it was fixed by turning the AC off then back on. The problem is we have to do this after most engine restarts. Lexus HQ has acknowledge a problem that it is working on. Does this sound familiar to anyone? Pls I have this issue. Has yours been solved??? Kindly assist with a solution. Regards Quote Link to comment Share on other sites More sharing options...
