1998 Es Door Lock Problem.
Problem:
I can NOT unlock the doors via the Key FOB. It does however lock and open the trunk (from the key fob) but no unlocking the doors. Any help? Maybe fuse or something simple? Any signs that might stick out?
I could not look at fuses etc since it was before work.
That is truly odd. Perhaps the chip that controls the unlock mechanism on the remote is broken. Do you have another remote to test this?
I tried another key FOB this am real quick and nothing. I am going to try the internal lock tonight (see if it works, check door and ECM fuses, and see if everything else works (lights, radio etc). Outside of that I need some help.....
