Radiator Upgrade
One day i was apparently wasted and threw away my radiator fan shroud....come to find out this caused the colapse of my ac compressor....so i went out and bought 2 10 inch electric fans from discount and added them to my radiator and that eliminates the clutch driven fan on your water pump. the wiring is very simple just hook the positive end to a 12volt source that is only on when the car is on. put a fuse in line if you want. the whole process took me about 1.5 hours. no modifying anything just put it on, hook it up and drive away. I put washers in front of the bolt that held the fan clutch on to even the space out. it runs cool, i can feel the air being sucked in from the front of my car!! well worth the $128
