mdscorp Posted April 4, 2006 Share Posted April 4, 2006 I am thinking about replacing the axle assy on my 93 ES300 after researching parts in the internet I realize apparently the right axle is different of the left axle ? I have also seen different brands of reconditioned axles. can anybody recommend some brand over others ? is replacing the 2 axles a DIY task ? thanks Quote Link to comment Share on other sites More sharing options...
Capk Posted April 8, 2006 Share Posted April 8, 2006 I am thinking about replacing the axle assy on my 93 ES300 after researching parts in the internet I realize apparently the right axle is different of the left axle ? I have also seen different brands of reconditioned axles. can anybody recommend some brand over others ? is replacing the 2 axles a DIY task ? thanks Had both replaced professionally on my ES300 1992 and the job IS straightforward, but be sure you have the correct tools, safe elevation of the front end, an assistant and plenty of muscle power (to disconnect the ball joints). Wheel alignment afterwards is strongly recommended. Quote Link to comment Share on other sites More sharing options...
