LRP_LS400 Posted March 20, 2006 Posted March 20, 2006 where can i find a double din kit that will fit my92 LS400? one similar to the picture?
LRP_LS400 Posted March 22, 2006 Author Posted March 22, 2006 okay so i found it for myself, but this kit needs some modifiying to fit a double din here s a link http://www.metraonline.com/downloads/pdf/T...INST99-8156.pdf good luck
MadMax96 Posted March 23, 2006 Posted March 23, 2006 I don't think it could be modified to accept a double DIN head unit (easily). The top edge of the upper opening probably isn't high enough on the bracket to allow a double DIN HU to fit if the bottom portion was cut out. That kit might be a good start to fabricate what you need though since it includes internal brackets.
azmalu Posted October 27, 2006 Posted October 27, 2006 hey guys i have a es but just got ls same thing...very little mod had to be done metra kit I bought brackets in the back was the only pia.....basically its designed to fit single din and have ashtray holder etc in bottom portion..
