Engine Coolant Temp Sensor
The diagnostic code P0125 popped up on my '99 GS300.
The code is for: Clsd Loop Fuel Ctrl Insufficient Coolant Temp.
From the diagnostic pdf file I read for the GS its either the thermostat or the engine coolant temp sensor.
I know where the thermostat is but where is the engine coolant temperature sensor?
Did you fix your oxygen sensor yet (you mentioned it in a previous post)? A failed O2 sensor can cause this code.
hey guytelefunken,
how would a bad o2 sensor cause the P0125 code to pop up. how is the o2 sensor related to engine coolant temp? i was just wondering. let me know. thanks for all your help.
  • 4 years later...
